Zum Hauptinhalt wechseln
LeapFrog LeapPad Ultra Repair Speaker Replacement
Was du brauchst
  1. LeapFrog LeapPad Ultra Repair Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapFrog LeapPad Ultra Repair Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapFrog LeapPad Ultra Repair Speaker Replacement: Schritt 3, Bild 1 von 1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapFrog LeapPad Ultra Repair Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapFrog LeapPad Ultra Repair Speaker Replacement: Schritt 5, Bild 1 von 1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra Repair Speaker Replacement: Schritt 6, Bild 1 von 2 LeapFrog LeapPad Ultra Repair Speaker Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
  7. LeapFrog LeapPad Ultra Repair Speaker Replacement, Speaker: Schritt 7, Bild 1 von 1
    • Find the screws on the bottom of the device holding down the button and speakers board.
  8. LeapFrog LeapPad Ultra Repair Speaker Replacement: Schritt 8, Bild 1 von 2 LeapFrog LeapPad Ultra Repair Speaker Replacement: Schritt 8, Bild 2 von 2
    • There should be a plastic covering over the speaker, carefully pull on the opposite side from the plastic clip holding it in place.
    • Excessive force can break the plastic clip, only use enough for to remove it gently
  9. LeapFrog LeapPad Ultra Repair Speaker Replacement: Schritt 9, Bild 1 von 2 LeapFrog LeapPad Ultra Repair Speaker Replacement: Schritt 9, Bild 2 von 2
    • Lift the button and speaker board, and turn it over, revealing the other side of the board.
  10. LeapFrog LeapPad Ultra Repair Speaker Replacement: Schritt 10, Bild 1 von 2 LeapFrog LeapPad Ultra Repair Speaker Replacement: Schritt 10, Bild 2 von 2
    • Find the ribbon cable connection and with a small plastic tool flip the plastic holding it down up.
    • You can now safely remove the ribbon cable by gently pulling it out of the slot.
    • Trying to remove the cable with brute force will damage the cable.
Abschluss
USF Tampa, Team 4-99, Meier Fall 2015 Mitglied von USF Tampa, Team 4-99, Meier Fall 2015
USFT-MEIER-F15S4G99
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Where can i buy a replacement speaker at to do this?
anthonydesiato2002 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 1,021
