Zum Hauptinhalt wechseln
LeapFrog LeapTV Controller Button Replacement
Was du brauchst
  1. LeapFrog LeapTV Controller Button Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use the Metal Spudger to push the release clip on the battery cover.
  2. LeapFrog LeapTV Controller Button Replacement: Schritt 2, Bild 1 von 1
    • Lift the cover off.
  3. LeapFrog LeapTV Controller Button Replacement: Schritt 3, Bild 1 von 1
    • The battery holder is now visible with the removal of the cover.
  4. LeapFrog LeapTV Controller Button Replacement, Buttons: Schritt 4, Bild 1 von 1
    • Use the screwdriver to remove the eight 8.7mm PH1 Phillips head screws.
  5. LeapFrog LeapTV Controller Button Replacement: Schritt 5, Bild 1 von 1
    • Slightly lift up on the back cover until the handle covers are free to rotate.
  6. LeapFrog LeapTV Controller Button Replacement: Schritt 6, Bild 1 von 1
    • Slide the the side of the handle facing you to the left to reveal the "A" and "B" button circuit board.
  7. LeapFrog LeapTV Controller Button Replacement: Schritt 7, Bild 1 von 1
    • Use the screwdriver to remove the three 8.5mm PH1 Phillips head screws.
  8. LeapFrog LeapTV Controller Button Replacement: Schritt 8, Bild 1 von 1
    • Lift up on the circuit board and move it to the side.
    • Be careful to not cause excess stress to the connecting wires when handling the circuit board. Excess stress can cause solder points to break.
  9. LeapFrog LeapTV Controller Button Replacement: Schritt 9, Bild 1 von 1
    • Use the plastic opening tool to release the buttons from the controller casing.
  10. LeapFrog LeapTV Controller Button Replacement: Schritt 10, Bild 1 von 1
    • Remove the "A" and "B" buttons by pulling up on one of the buttons.
  11. LeapFrog LeapTV Controller Button Replacement: Schritt 11, Bild 1 von 1
    • Buttons are now removed.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
IUPUI, Team S4-G2, Baechle Spring 2017 Mitglied von IUPUI, Team S4-G2, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 359
