Einleitung
This guide will show you how to replace the joy stick on the controller.
Was du brauchst
Use the screwdriver to remove the eight 8.7 mm PH1 Phillips head screws.
Slide the cover on the back side of the controller covering the joy stick out of the way.
Turn and lift the circuit board with button attacked out of the hole. Do not detach the circuit.
Fast fertig!
Abschluss
