Zum Hauptinhalt wechseln
LeapFrog Scribble and Write Eraser Slider Cleaning
Was du brauchst
  1. LeapFrog Scribble and Write Eraser Slider Cleaning, Eraser Slider: Schritt 1, Bild 1 von 1
    • Turn the toy over so the back is facing upward.
  2. LeapFrog Scribble and Write Eraser Slider Cleaning: Schritt 2, Bild 1 von 1
    • Using a Phillips #0 screwdriver, carefully remove all 9 screws.
    • Set aside screws in a safe place for later reassembly.
  3. LeapFrog Scribble and Write Eraser Slider Cleaning: Schritt 3, Bild 1 von 1
    • Remove the back of the toy by carefully lifting it up.
  4. LeapFrog Scribble and Write Eraser Slider Cleaning: Schritt 4, Bild 1 von 2 LeapFrog Scribble and Write Eraser Slider Cleaning: Schritt 4, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the two screws that secure the screen to the motherboard.
    • Set aside screws in a safe place.
    • Gently remove the motherboard to expose the display screen and eraser slider.
  5. LeapFrog Scribble and Write Eraser Slider Cleaning: Schritt 5, Bild 1 von 1
    • Carefully remove the display screen, leaving the eraser slider attached.
  6. LeapFrog Scribble and Write Eraser Slider Cleaning: Schritt 6, Bild 1 von 2 LeapFrog Scribble and Write Eraser Slider Cleaning: Schritt 6, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the eraser slider.
  7. LeapFrog Scribble and Write Eraser Slider Cleaning: Schritt 7, Bild 1 von 1
    • Lastly, use a soft towel to clean the eraser slider, removing any debris.
    • When all previous seven steps are completed, go backwards and re-screw and put together your The LeapFrog Scribble and Write
Abschluss
Shang
328 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 1-5, Nance Spring 2016 Mitglied von USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 721
