Zum Hauptinhalt wechseln
LeapFrog Scribble and Write Motherboard Replacement
Was du brauchst
  1. LeapFrog Scribble and Write Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Use a Phillips head screwdriver to remove the screw from the battery compartment on the back of the toy.
  2. LeapFrog Scribble and Write Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the back battery cover and all of the batteries.
  3. LeapFrog Scribble and Write Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips screwdriver to remove the nine case screws from the back of the toy.
    • Be careful to keep track of the screws.
  4. LeapFrog Scribble and Write Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the back cover from your toy.
  5. LeapFrog Scribble and Write Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Using a Phillips screwdriver, remove the four screws from the motherboard.
  6. LeapFrog Scribble and Write Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the keyboard ribbon from the motherboard.
  7. LeapFrog Scribble and Write Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the speaker wires from the motherboard with your soldering iron.
  8. LeapFrog Scribble and Write Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the battery wires from the motherboard with the soldering iron.
  9. LeapFrog Scribble and Write Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove the switch wires from the motherboard with the soldering iron.
  10. LeapFrog Scribble and Write Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Remove the pen wires from the motherboard with the soldering iron.
  11. LeapFrog Scribble and Write Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Remove the volume control switch from the motherboard with the soldering iron.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Shang
328 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 1-5, Nance Spring 2016 Mitglied von USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 17
Insgesamt: 680
