Einleitung
In this guide, you will learn how to replace a LeapFrog Scribble and Write motherboard. You will need a soldering iron to remove certain wiring from the motherboard.
Was du brauchst
Use a Phillips head screwdriver to remove the screw from the battery compartment on the back of the toy.
Use a Phillips screwdriver to remove the nine case screws from the back of the toy.
Remove the volume control switch from the motherboard with the soldering iron.
Eine weitere Person hat diese Anleitung absolviert.
