Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
The purpose of this guide is to replace the LeapPad's battery. The battery is essential to receiving any form of functionality from the device. Without a working battery the device is powerless. Once the replacement is finished, be sure to properly dispose of the old battery at appropriate locations such as a batter recycling center.
  1. Remove the barcode covering the two screws on the lower back of the Leap Pad.
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. Remove the two 5 mm screws that were covered by the sticker.
    • Remove the two 5 mm screws that were covered by the sticker.
  3. iPhone LCD Display Fix Kits
    Die Budgetoption, abgedeckt durch unsere lebenslange Garantie.
    Kits kaufen
    Reduziere die Reparaturkosten, nicht die Qualität.
    Kits kaufen
  4. Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  5. Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  6. Remove the hard plastic casing, exposing the motherboard and battery.
    • Remove the hard plastic casing, exposing the motherboard and battery.
  7. The battery will be glued down, so use the flat end of the spudger to pry out the battery pack. Then using your fingers, grab the wire at the connection point and unplug the battery connector. Replace the battery with a new one. The battery will be glued down, so use the flat end of the spudger to pry out the battery pack. Then using your fingers, grab the wire at the connection point and unplug the battery connector. Replace the battery with a new one.
    • The battery will be glued down, so use the flat end of the spudger to pry out the battery pack. Then using your fingers, grab the wire at the connection point and unplug the battery connector. Replace the battery with a new one.
Abschluss
To reassemble the device, follow these instructions in reverse order.
6 weitere Nutzer haben diese Anleitung absolviert.
Ryan Arredondo
231 Reputation
1 Anleitung geschrieben
USF Tampa, Team 4-99, Meier Fall 2015 Mitglied von USF Tampa, Team 4-99, Meier Fall 2015
USFT-MEIER-F15S4G99
4 Mitglieder
10 Anleitungen geschrieben
Hi Ryan, will removing the battery delete any of the downloaded apps and saved files?
Michael - Antwort
I’m not Ryan, but I just did this process and the apps and files are all still there.
Kivi Shapiro - Antwort
What is a spudger and where do I get a battery
P Mac - Antwort
Hello, if anyone still has this leappad Ultra and wanted to purchase a new battery. I have found a retail store https://batteryclerk.com/ The price is reasonable, and I'm just waiting for the batteries to arrive.
Mike Silva - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 21
Letzten 30 Tage: 144
Insgesamt: 12,222
