Zum Hauptinhalt wechseln
LeapPad Ultra Battery Replacement
Was du brauchst
  1. LeapPad Ultra Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapPad Ultra Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapPad Ultra Battery Replacement: Schritt 3, Bild 1 von 1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapPad Ultra Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapPad Ultra Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapPad Ultra Battery Replacement: Schritt 6, Bild 1 von 2 LeapPad Ultra Battery Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
Abschluss
To reassemble the device, follow these instructions in reverse order.
7 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 4-99, Meier Fall 2015 Mitglied von USF Tampa, Team 4-99, Meier Fall 2015
USFT-MEIER-F15S4G99
4 Mitglieder
10 Anleitungen geschrieben
4 Kommentare
Hi Ryan, will removing the battery delete any of the downloaded apps and saved files?
Michael - Antwort
I’m not Ryan, but I just did this process and the apps and files are all still there.
Kivi Shapiro - Antwort
What is a spudger and where do I get a battery
P Mac - Antwort
Hello, if anyone still has this leappad Ultra and wanted to purchase a new battery. I have found a retail store https://batteryclerk.com/ The price is reasonable, and I'm just waiting for the batteries to arrive.
Mike Silva - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 26
Insgesamt: 16,196
