Zum Hauptinhalt wechseln
Leapfrog LeapPad 3 Motherboard Replacement
Was du brauchst
  1. Leapfrog LeapPad 3 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 3 Leapfrog LeapPad 3 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 3 Leapfrog LeapPad 3 Motherboard Replacement, Battery: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
    • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
    • You will not need to pry the case off.
  2. Leapfrog LeapPad 3 Motherboard Replacement: Schritt 2, Bild 1 von 3 Leapfrog LeapPad 3 Motherboard Replacement: Schritt 2, Bild 2 von 3 Leapfrog LeapPad 3 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Unplug the battery from the motherboard with your hands.
    • The battery sits to the right of the motherboard.
  3. Leapfrog LeapPad 3 Motherboard Replacement: Schritt 3, Bild 1 von 2 Leapfrog LeapPad 3 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Pry the battery gently off of the plastic platform with an opening tool.
    • Do not to puncture the battery, as the material inside can be dangerous.
  4. Leapfrog LeapPad 3 Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 2 Leapfrog LeapPad 3 Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 2
    • Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
  5. Leapfrog LeapPad 3 Motherboard Replacement: Schritt 5, Bild 1 von 3 Leapfrog LeapPad 3 Motherboard Replacement: Schritt 5, Bild 2 von 3 Leapfrog LeapPad 3 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Remove the three 6 mm phillips head screws holding the motherboard to the display assembly.
  6. Leapfrog LeapPad 3 Motherboard Replacement: Schritt 6, Bild 1 von 3 Leapfrog LeapPad 3 Motherboard Replacement: Schritt 6, Bild 2 von 3 Leapfrog LeapPad 3 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Carefully lift the motherboard out of the case, exposing the last remaining cord on the underside of the motherboard.
    • Disconnect the gold display assembly cord with an opening tool to fully disconnect the motherboard.
    • The device was rotated 180 degrees in order to unplug the display assembly cord.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Matt Irvine
952 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 16-2, Blackwell Winter 2016 Mitglied von USF Tampa, Team 16-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G2
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 16
Insgesamt: 1,424
