Zum Hauptinhalt wechseln
Leapfrog LeapPad 3 Speaker Replacement
Was du brauchst
  1. Leapfrog LeapPad 3 Speaker Replacement, Battery: Schritt 1, Bild 1 von 3 Leapfrog LeapPad 3 Speaker Replacement, Battery: Schritt 1, Bild 2 von 3 Leapfrog LeapPad 3 Speaker Replacement, Battery: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
    • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
    • You will not need to pry the case off.
  2. Leapfrog LeapPad 3 Speaker Replacement: Schritt 2, Bild 1 von 3 Leapfrog LeapPad 3 Speaker Replacement: Schritt 2, Bild 2 von 3 Leapfrog LeapPad 3 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Unplug the battery from the motherboard with your hands.
    • The battery sits to the right of the motherboard.
  3. Leapfrog LeapPad 3 Speaker Replacement: Schritt 3, Bild 1 von 2 Leapfrog LeapPad 3 Speaker Replacement: Schritt 3, Bild 2 von 2
    • Pry the battery gently off of the plastic platform with an opening tool.
    • Do not to puncture the battery, as the material inside can be dangerous.
  4. Leapfrog LeapPad 3 Speaker Replacement, Speaker: Schritt 4, Bild 1 von 2 Leapfrog LeapPad 3 Speaker Replacement, Speaker: Schritt 4, Bild 2 von 2
    • Disconnect the audio cord from the motherboard using a plastic opening tool.
    • When re-plugging this cord be sure it is flush with the slot, otherwise the speaker and directional pad will malfunction.
    • Use caution when unplugging, and re-plugging the ribbon cord as they are fragile.
  5. Leapfrog LeapPad 3 Speaker Replacement: Schritt 5, Bild 1 von 3 Leapfrog LeapPad 3 Speaker Replacement: Schritt 5, Bild 2 von 3 Leapfrog LeapPad 3 Speaker Replacement: Schritt 5, Bild 3 von 3
    • Unscrew the five 6.0 mm phillips head screws from the board containing the audio jack and directional pad.
  6. Leapfrog LeapPad 3 Speaker Replacement: Schritt 6, Bild 1 von 3 Leapfrog LeapPad 3 Speaker Replacement: Schritt 6, Bild 2 von 3 Leapfrog LeapPad 3 Speaker Replacement: Schritt 6, Bild 3 von 3
    • Unscrew the three 6.5 mm phillips head screws holding down the speaker to the right of the audio jack.
    • Remove the board and speaker from the device.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Matt Irvine
952 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 16-2, Blackwell Winter 2016 Mitglied von USF Tampa, Team 16-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G2
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Where can I purchase a replacement audio board /speaker for the LeapPad3?
lizchilds - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 16
Insgesamt: 884
