Zum Hauptinhalt wechseln
Leapfrog My Own Leaptop Battery Replacement Guide
Was du brauchst
  1. Leapfrog My Own Leaptop Battery Replacement Guide, Battery: Schritt 1, Bild 1 von 1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Battery Replacement Guide: Schritt 2, Bild 1 von 1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Battery Replacement Guide: Schritt 3, Bild 1 von 2 Leapfrog My Own Leaptop Battery Replacement Guide: Schritt 3, Bild 2 von 2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 14-6, Lacy Spring 2016 Mitglied von USF Tampa, Team 14-6, Lacy Spring 2016
USFT-LACY-S16S14G6
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Hi Jonathan! Your article is very helpful. But I have a big question now. I have opened the leaptop and see that membrane should be replaced. But where can I buy the membrane separately? Please help!
Alina Timchenko - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 44
Insgesamt: 3,078
