Einleitung
The step by step guide is designed to assist with button replacement of the Leapfrog My Own Leaptop.
Was du brauchst
Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
Remove the three AA batteries.
Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
Remove the three 10mm screws from the upper left hand corner white plastic piece with a PH1 phillips head screwdriver.
Unscrew the five 4mm screws from the plastic membrane with a PH1 phillips head screwdriver.
Gently grab the membrane and peal it upwards.
Carefully remove the membrane and set it to the side.
From this step you can also clean the membrane of any residue with a lightly dampened paper towel.
Ensure that the membrane is completely dry before reassembly.
From here, each button is able to be removed for cleaning or replacement.
Using a tweezers or needle nose pliers, remove the necessary pieces from the device.
2 weitere Personen haben diese Anleitung absolviert.
6 Kommentare
Very useful. but where to get a new membrane? please help
Didn't work. I'll buy a new toy.
Is the screen on this suppose to light up?
I was wondering if the screen is suppose to light up because the one I have doesnt
thank you very much
