Zum Hauptinhalt wechseln
Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide
Was du brauchst
  1. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Battery: Schritt 1, Bild 1 von 1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: Schritt 2, Bild 1 von 1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: Schritt 3, Bild 1 von 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: Schritt 3, Bild 2 von 2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
  4. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Keyboard Buttons: Schritt 4, Bild 1 von 1
    • Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
  5. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: Schritt 5, Bild 1 von 1
    • Carefully remove back of the device.
    • Make sure not to rip the wires when lifting the cover off.
  6. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: Schritt 6, Bild 1 von 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: Schritt 6, Bild 2 von 2
    • Remove the three 10mm screws from the upper left hand corner white plastic piece with a PH1 phillips head screwdriver.
    • Unscrew the five 4mm screws from the plastic membrane with a PH1 phillips head screwdriver.
  7. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: Schritt 7, Bild 1 von 1
    • Remove the white plastic piece and place it to the side.
  8. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: Schritt 8, Bild 1 von 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: Schritt 8, Bild 2 von 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: Schritt 8, Bild 3 von 3
    • Gently grab the membrane and peal it upwards.
    • Carefully remove the membrane and set it to the side.
    • From this step you can also clean the membrane of any residue with a lightly dampened paper towel.
    • Ensure that the membrane is completely dry before reassembly.
  9. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: Schritt 9, Bild 1 von 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: Schritt 9, Bild 2 von 2
    • Gently lift and remove the foam piece
  10. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: Schritt 10, Bild 1 von 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: Schritt 10, Bild 2 von 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: Schritt 10, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • From here, each button is able to be removed for cleaning or replacement.
    • Using a tweezers or needle nose pliers, remove the necessary pieces from the device.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 14-6, Lacy Spring 2016 Mitglied von USF Tampa, Team 14-6, Lacy Spring 2016
USFT-LACY-S16S14G6
4 Mitglieder
6 Anleitungen geschrieben
6 Kommentare
Very useful. but where to get a new membrane? please help
Alina Timchenko - Antwort
Didn't work. I'll buy a new toy.
victoria_nglover19 - Antwort
Is the screen on this suppose to light up?
stewartmelinda41 - Antwort
I was wondering if the screen is suppose to light up because the one I have doesnt
thank you very much
Njabulo Mbele - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 55
Insgesamt: 5,297
