Zum Hauptinhalt wechseln
Left-Handed Fender Squier Electric Guitar String Replacement
Was du brauchst
  1. Left-Handed Fender Squier Electric Guitar String Replacement, String: Schritt 1, Bild 1 von 1
    • Place the guitar on a flat surface with the tuning pegs facing you.
  2. Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 2, Bild 1 von 3 Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 2, Bild 2 von 3 Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 2, Bild 3 von 3
    • Use a guitar string winder to drop the tuning and loosen each of the strings.
    • Use a wire cutter to cut each of the strings in the middle of the fretboard.
    • Guitar strings can be sharp and cutting them without loosening them first can cause harm to the user.
  3. Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 3, Bild 1 von 3 Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 3, Bild 2 von 3 Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 3, Bild 3 von 3
    • To remove the top half of the string from the guitar, turn the tuning pegs to loosen the string until you can pull it from the guitar.
    • Remove the bottom half of the string by pushing each string through the front of the bridge saddle and pulling it out through the back.
  4. Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 4, Bild 1 von 3 Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 4, Bild 2 von 3 Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 4, Bild 3 von 3
    • Start restringing with the thickest (E) string.
    • Push the new string through the back of the bridge and pull it through the front of the saddle.
  5. Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 5, Bild 1 von 2 Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 5, Bild 2 von 2
    • Pull the string so that it is parallel with the fretboard.
    • Place the string through the first tuning post.
  6. Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 6, Bild 1 von 3 Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 6, Bild 2 von 3 Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 6, Bild 3 von 3
    • Hold the guitar and place your thumb on the first fret to ensure the string stays in place.
    • Insert the guitar string winder into the the tuning peg.
    • Turn the guitar string winder clockwise to tighten the string.
    • The process of replacing strings A, G, and B is the same and you can follow steps 4 through 6.
    • Only tighten the string until it stays in place. If you tighten it too much the string might snap which may result in injury.
  7. Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 7, Bild 1 von 3 Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 7, Bild 2 von 3 Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 7, Bild 3 von 3
    • Insert the D string from the back of the bridge and pull it through the saddle at the front of the guitar.
    • Pull the wire so that it is parallel to the fretboard.
    • Make sure to place the string under the string tree.
  8. Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 8, Bild 1 von 3 Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 8, Bild 2 von 3 Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 8, Bild 3 von 3
    • Insert the guitar string winder into the the tuning peg and turn it clockwise.
    • The process of replacing the last e string is the same as steps 7 and 8.
    • Only tighten the string until it stays in place. If you tighten it too much the string might snap which may cause injury.
  9. Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 9, Bild 1 von 2 Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 9, Bild 2 von 2
    • Use a wire cutter to cut the extra length of wire.
    • You should leave an inch or two of each string onto the tuning posts to allow for a greater tuning range.
  10. Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 10, Bild 1 von 2 Left-Handed Fender Squier Electric Guitar String Replacement: Schritt 10, Bild 2 von 2
    • Use a guitar string winder to tighten/loosen strings in order to correctly tune each string to its respective note.
    • The usual 6 notes on a guitar are E, A, D, G, B, e, in the order of the thickest string to the thinnest.
    • Smartphone apps or guitar tuners will help with the tuning process.
    • While tuning, wiggle each string back and forth to remove slack and prevent slipping so the strings will maintain in tune longer.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
UC Davis, Team 2-3, Morris Spring 2023 Mitglied von UC Davis, Team 2-3, Morris Spring 2023
UCD-MORRIS-S23S2G3
3 Mitglieder
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 31
Insgesamt: 273
