Einleitung
The USB cable is what connects the toy pad to the video game console, allowing you to play the game. This guide shows how to remove the USB cable from the toy pad.
Was du brauchst
Use the metal spudger to gently pry open the corners of the top cover.
Pull the white connector away from the motherboard, keeping the white connector parallel to the board.
Remove the USB cable from the toy pad.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
