Zum Hauptinhalt wechseln
Leica CS20 Screen Replacement
  1. Leica CS20 Screen Replacement, Oops..: Schritt 1, Bild 1 von 1
    • I did it again!
  2. Leica CS20 Screen Replacement, Order a new replacement screen: Schritt 2, Bild 1 von 1
    • I am tired to pay 1200 EUR to Leica service center, so I ordered a new replacement screent here: www.xsurveying.com/product/new-leica-cs20-digitizer-screen-replacement Price with delivery was around 185 EUR
  3. Leica CS20 Screen Replacement, New touchscreen: Schritt 3, Bild 1 von 1
    • The package arrived in two weeks. It contained a well packed touchscreen
  4. Leica CS20 Screen Replacement, Prepare a clean area: Schritt 4, Bild 1 von 1
    • Place controller on a desk
  5. Leica CS20 Screen Replacement, Unscrew all the bolts: Schritt 5, Bild 1 von 1
    • …and unscrew all the bolts
  6. Leica CS20 Screen Replacement, Remove the bottom lid: Schritt 6, Bild 1 von 1
    • Also, remove the bottom plastic lid
  7. Leica CS20 Screen Replacement, Unscrew two black bolts: Schritt 7, Bild 1 von 1
    • …in order to unscrew these two black bolts. Place them separately.
  8. Leica CS20 Screen Replacement, Unscrew 2 bolts: Schritt 8, Bild 1 von 1
    • These bolts also should be unscrewed.
  9. Leica CS20 Screen Replacement, Remove the back cover: Schritt 9, Bild 1 von 1
    • After that the controller’s back wall can be removed
  10. Leica CS20 Screen Replacement, Unscrew four bolts: Schritt 10, Bild 1 von 1
    • Unscrew these four bolts
  11. Leica CS20 Screen Replacement, Unscrew two bolts: Schritt 11, Bild 1 von 1
    • Unscrew these two small bolts. Place them separately.
  12. Leica CS20 Screen Replacement, Unscrew two plastic bolts: Schritt 12, Bild 1 von 1
    • Unscrew these two plastic bolts. Place them separately.
  13. Leica CS20 Screen Replacement, Unscrew two bolts: Schritt 13, Bild 1 von 1
    • Now the last two bolts can be unscrewed
  14. Leica CS20 Screen Replacement, Remove the cage: Schritt 14, Bild 1 von 1
    • This GNSS antenna connector will be disconnected when you pull out the metal cage
  15. Leica CS20 Screen Replacement, Pull out the board: Schritt 15, Bild 1 von 1
    • …than pull out this board carefully
  16. Leica CS20 Screen Replacement, See theribbon cable: Schritt 16, Bild 1 von 1
    • So you wil get an access to this ribbon cable
  17. Leica CS20 Screen Replacement, Unclip the connector: Schritt 17, Bild 1 von 1
    • ...unclip it!
  18. Leica CS20 Screen Replacement, Unclip the connector: Schritt 18, Bild 1 von 1
    • Also, unclip the kyocera-connector to this ribbon cable
  19. Leica CS20 Screen Replacement, Act carefully!: Schritt 19, Bild 1 von 1
    • Proceed with great caution!
  20. Leica CS20 Screen Replacement, Unclip the cable: Schritt 20, Bild 1 von 1
    • Unclip the touchscreen ribbon cable
  21. Leica CS20 Screen Replacement, Remove the whole board: Schritt 21, Bild 1 von 1
    • Now you are able to remove the whole board…
  22. Leica CS20 Screen Replacement, Change the screen!: Schritt 22, Bild 1 von 1
    • And finally, change the screen!
Abschluss
Angehängte Dokumente
Sandu Tuzarean
345 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 9
Letzte 30 Tage: 47
Insgesamt: 197
