Zum Hauptinhalt wechseln
Leica Z2X Lens Motor Replacement
Was du brauchst
  1. Leica Z2X Lens Motor Replacement, Remove the Bottom Screws: Schritt 1, Bild 1 von 1
    • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
    • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
  2. Leica Z2X Lens Motor Replacement, Open the Back Door: Schritt 2, Bild 1 von 1
    • Open the back door on the camera by pushing down on the door latch.
  3. Leica Z2X Lens Motor Replacement, Remove the Bottom Plate: Schritt 3, Bild 1 von 1
    • Apply pressure to the bottom plate and it will pop off.
    • From here, you can replace the bottom plate, or continue on to further steps.
  4. Leica Z2X Lens Motor Replacement, Lens Motor: Schritt 4, Bild 1 von 1
    • Having opened the camera and removed the bottom plate, unscrew the five screws marked in the picture.
    • The screw marked in blue is a tiny bit harder to find because it's in a crevice. Don't miss it!
  5. Leica Z2X Lens Motor Replacement: Schritt 5, Bild 1 von 1
    • Apply pressure until the piece you unscrewed in the last step pops off.
  6. Leica Z2X Lens Motor Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the four screws on the back of this piece to the lower-left corner of the lens.
  7. Leica Z2X Lens Motor Replacement: Schritt 7, Bild 1 von 1
    • Removing the lens motor cover, you should be left with these four pieces.
  8. Leica Z2X Lens Motor Replacement: Schritt 8, Bild 1 von 1
    • Located underneath these four pieces is the lens motor.
  9. Leica Z2X Lens Motor Replacement: Schritt 9, Bild 1 von 1
    • Now that you've removed the bottom plate, you can pull apart the front and back covers.
    • Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
  10. Leica Z2X Lens Motor Replacement: Schritt 10, Bild 1 von 1
    • Next, the back cover.
    • Apply pressure to remove the back plate.
    • Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
    • The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
  11. Leica Z2X Lens Motor Replacement: Schritt 11, Bild 1 von 1
    • You should now have removed the front and back plates.
  12. Leica Z2X Lens Motor Replacement: Schritt 12, Bild 1 von 1
    • Remove the four screws holding on the front panel surrounding the lens.
  13. Leica Z2X Lens Motor Replacement: Schritt 13, Bild 1 von 1
    • Remove the three gears under the panel you removed in the last step and the lens motor should be able to be removed.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Zachary
46 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 18-19, Garner Spring 2011 Mitglied von Cal Poly, Team 18-19, Garner Spring 2011
CPSU-GARNER-S11S18G19
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 2,800
