Zum Hauptinhalt wechseln
Lenovo 100e Chromebook 2nd Gen Camera Replacement
Was du brauchst
  1. Lenovo 100e Chromebook 2nd Gen Camera Replacement, Screen Bezel: Schritt 1, Bild 1 von 1
    • Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
  2. Lenovo 100e Chromebook 2nd Gen Camera Replacement: Schritt 2, Bild 1 von 1
    • Insert the spudger into the gap between the hinges and pull up to detach the connections.
  3. Lenovo 100e Chromebook 2nd Gen Camera Replacement: Schritt 3, Bild 1 von 1
    • Remove the screen bezel from the laptop.
  4. Lenovo 100e Chromebook 2nd Gen Camera Replacement, Camera: Schritt 4, Bild 1 von 1
    • Using the opening pick, pry the camera from the front of the laptop.
  5. Lenovo 100e Chromebook 2nd Gen Camera Replacement: Schritt 5, Bild 1 von 1
    • Carefully pinch and pull on the connection between the camera and the motherboard.
    • The camera is now loose and can be removed.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 499
