Einleitung
This guide will show you how to access and replace the hinges in your Lenovo 100e Chromebook 2nd Gen laptop, in the circumstance that your device is no longer opening/closing correctly.
Was du brauchst
Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
Open the laptop and lay it flat.
Go along the edge of the keyboard with an opening tool until it pops loose.
Lift the keyboard connectors up using an opening pick.
Remove the connectors from their sockets.
Using an opening pick, push on the connection where the wires are connected to the motherboard.
Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
Insert the spudger into the gap between the hinges and pull up to detach the connections.
Remove the four 3.4 mm screws holding the screen in place using the Phillips #00 screwdriver.
Peel back the protective tape over the display cable using the spudger.
Gently lift the black bar latch holding the cable in place, until the cable becomes loose.
Pull the cable free and remove the display.
Use the Phillips #0 screwdriver to remove the six 4.7 mm screws located on the bottom half of each hinge.
Use the Phillips #00 screwdriver to remove the ten 3.4 mm screws located on the upper hinge assembly.
Move the screen assembly perpendicular to the keyboard assembly.
Remove the hinges by pulling straight up.
Ein Kommentar
Any Ideas on how to repair popped rivets from the hinges? I've tried epoxy without much luck, but I've got hinges popped at the top and bottom of the display.
