Einleitung
This guide will show the steps needed to take out and replace the motherboard in the Lenovo Chromebook 100e 2nd gen. This repair is a last ditch effort to fix your broken device; only do this repair if there is significant water or structural damage to the device causing complete graphical and functional failure.
Was du brauchst
Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
Open the laptop and lay it flat.
Go along the edge of the keyboard with an opening tool until it pops loose.
Lift the keyboard connectors up using an opening pick.
Remove the connectors from their sockets.
Using an opening pick, push on the connection where the wires are connected to the motherboard.
Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
Insert the spudger into the gap between the hinges and pull up to detach the connections.
Remove the four 3.4 mm screws holding the screen in place using the Phillips #00 screwdriver.
Peel back the protective tape over the display cable using the spudger.
Gently lift the black bar latch holding the cable in place, until the cable becomes loose.
Pull the cable free and remove the display.
Use the Phillips #0 screwdriver to remove the six 4.7 mm screws located on the bottom half of each hinge.
Use the Phillips #00 screwdriver to remove the ten 3.4 mm screws located on the upper hinge assembly.
Move the screen assembly perpendicular to the keyboard assembly.
Remove the hinges by pulling straight up.
Use the spudger to disconnect the two ribbon cables.
Disconnect the black and white coaxial cables.
Remove the white Lenovo sticker over one of the screws.
Use the Phillips #0 screwdriver to remove the seven 3.8 mm screws.
