Zum Hauptinhalt wechseln
Lenovo 100e Chromebook 2nd Gen Speakers Replacement
Was du brauchst
  1. Lenovo 100e Chromebook 2nd Gen Speakers Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Speakers Replacement: Schritt 2, Bild 1 von 2 Lenovo 100e Chromebook 2nd Gen Speakers Replacement: Schritt 2, Bild 2 von 2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Speakers Replacement: Schritt 3, Bild 1 von 2 Lenovo 100e Chromebook 2nd Gen Speakers Replacement: Schritt 3, Bild 2 von 2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Speakers Replacement, Speakers: Schritt 4, Bild 1 von 1
    • Using an opening pick, disconnect the speakers from the headphone jack.
  5. Lenovo 100e Chromebook 2nd Gen Speakers Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 2 mm Phillips #0 screws holding both of the speakers in.
  6. Lenovo 100e Chromebook 2nd Gen Speakers Replacement: Schritt 6, Bild 1 von 1
    • The speakers are now loose and can be removed from the laptop.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 52
Insgesamt: 802
