Einleitung
This guide will show the steps needed to take out and replace the trackpad in the Lenovo Chromebook 100e 2nd gen. The only tool required for this guide is a Phillips head screwdriver. Make sure to be careful when pushing on the trackpad in step #2 to ensure the connections do not break.
Was du brauchst
Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
Open the laptop and lay it flat.
Go along the edge of the keyboard with an opening tool until it pops loose.
Lift the keyboard connectors up using an opening pick.
Remove the connectors from their sockets.
Push up on the side of the trackpad that faces the screen.
Pop the trackpad out and remove it from the laptop.
