Einleitung
This guide will show how to remove the screen for the Lenovo 100s Chromebook-11IBY. This removal will allow you to replace or upgrade the screen for your laptop.
Was du brauchst
Use the plastic opening tool on the recessed notch to gently pry each side of around the screen up.
Carefully pry up and underneath both the (left & right) hinges of the screen cover.
Use the opening tool on the inside of the screen plate and again on the sides to gently remove it.
Eine weitere Person hat diese Anleitung absolviert.
