Einleitung
This guide will show how to remove the speakers for the Lenovo 100s Chromebook-11IBY. This removal will allow you to replace or upgrade the speakers for your laptop.
Was du brauchst
Use a #0 Phillips screwdriver to remove the nine 6mm screws from the larger back plate.
Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
Locate the two sticker-like connecting wires (for the keyboard and touchpad).
Carefully unplug the orange circled (keyboard) wire from the keyboard plate.
Carefully unplug the yellow circled (touchpad) wire from the keyboard plate.
Then lift the keyboard plate up and place it to the side.
Locate the cable attaching the left speaker to the motherboard and unplug it by hand.
Then unplug the cable attaching the right speaker by hand.
Carefully pry the speaker up and free of the two notches holding it in place.
Remove the speaker.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
