Einleitung
This guide will show how to remove the mouse pad buttons from the Chromebook. Although not difficult, it does require removal of the battery, so make sure the battery is removed before proceeding to this guide.
Was du brauchst
Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
Remove six 3 mm screws from the battery with a Phillips #2 screwdriver.
Disconnect the wiring harness that connects the battery to the motherboard.
Lift the battery up and out of the laptop.
Disconnect the metallic electrical tape by gently pulling back away from the keypad.
