Zum Hauptinhalt wechseln
Lenovo 300e Chromebook Motherboard Replacement
Was du brauchst
  1. Lenovo 300e Chromebook Motherboard  Replacement, Back Cover: Schritt 1, Bild 1 von 3 Lenovo 300e Chromebook Motherboard  Replacement, Back Cover: Schritt 1, Bild 2 von 3 Lenovo 300e Chromebook Motherboard  Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook Motherboard  Replacement: Schritt 2, Bild 1 von 3 Lenovo 300e Chromebook Motherboard  Replacement: Schritt 2, Bild 2 von 3 Lenovo 300e Chromebook Motherboard  Replacement: Schritt 2, Bild 3 von 3
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook Motherboard  Replacement, Battery: Schritt 3, Bild 1 von 3 Lenovo 300e Chromebook Motherboard  Replacement, Battery: Schritt 3, Bild 2 von 3 Lenovo 300e Chromebook Motherboard  Replacement, Battery: Schritt 3, Bild 3 von 3
    • Remove six 3 mm screws from the battery with a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook Motherboard  Replacement: Schritt 4, Bild 1 von 3 Lenovo 300e Chromebook Motherboard  Replacement: Schritt 4, Bild 2 von 3 Lenovo 300e Chromebook Motherboard  Replacement: Schritt 4, Bild 3 von 3
    • Disconnect the wiring harness that connects the battery to the motherboard.
    • Lift the battery up and out of the laptop.
  5. Lenovo 300e Chromebook Motherboard  Replacement, Motherboard: Schritt 5, Bild 1 von 2 Lenovo 300e Chromebook Motherboard  Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • Remove the three silver 3 mm screws from the center of the metal cover using a Phillips #00 screwdriver.
  6. Lenovo 300e Chromebook Motherboard  Replacement: Schritt 6, Bild 1 von 3 Lenovo 300e Chromebook Motherboard  Replacement: Schritt 6, Bild 2 von 3 Lenovo 300e Chromebook Motherboard  Replacement: Schritt 6, Bild 3 von 3
    • Remove two 3 mm screws from the top of the metal cover using a Phillips #2 screwdriver.
    • Remove the metal cover from the laptop.
  7. Lenovo 300e Chromebook Motherboard  Replacement: Schritt 7, Bild 1 von 3 Lenovo 300e Chromebook Motherboard  Replacement: Schritt 7, Bild 2 von 3 Lenovo 300e Chromebook Motherboard  Replacement: Schritt 7, Bild 3 von 3
    • Remove the nine 3 mm screws from the motherboard using a Phillips #2 screwdriver.
    • Detach all the connectors from the motherboard.
  8. Lenovo 300e Chromebook Motherboard  Replacement: Schritt 8, Bild 1 von 3 Lenovo 300e Chromebook Motherboard  Replacement: Schritt 8, Bild 2 von 3 Lenovo 300e Chromebook Motherboard  Replacement: Schritt 8, Bild 3 von 3
    • Remove the tape using a spudger.
    • Disconnect the large cable connector.
    • Remove the motherboard from the laptop.
Abschluss
Ein Kommentar
where is the write protect screw located im trying to install windows on this model
Harvey Willis - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 42
Insgesamt: 1,231
