Zum Hauptinhalt wechseln
Lenovo 300e Chromebook Speakers Replacement
Was du brauchst
  1. Lenovo 300e Chromebook Speakers Replacement, Back Cover: Schritt 1, Bild 1 von 3 Lenovo 300e Chromebook Speakers Replacement, Back Cover: Schritt 1, Bild 2 von 3 Lenovo 300e Chromebook Speakers Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook Speakers Replacement: Schritt 2, Bild 1 von 3 Lenovo 300e Chromebook Speakers Replacement: Schritt 2, Bild 2 von 3 Lenovo 300e Chromebook Speakers Replacement: Schritt 2, Bild 3 von 3
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook Speakers Replacement, Battery: Schritt 3, Bild 1 von 3 Lenovo 300e Chromebook Speakers Replacement, Battery: Schritt 3, Bild 2 von 3 Lenovo 300e Chromebook Speakers Replacement, Battery: Schritt 3, Bild 3 von 3
    • Remove six 3 mm screws from the battery with a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook Speakers Replacement: Schritt 4, Bild 1 von 3 Lenovo 300e Chromebook Speakers Replacement: Schritt 4, Bild 2 von 3 Lenovo 300e Chromebook Speakers Replacement: Schritt 4, Bild 3 von 3
    • Disconnect the wiring harness that connects the battery to the motherboard.
    • Lift the battery up and out of the laptop.
  5. Lenovo 300e Chromebook Speakers Replacement, Speakers: Schritt 5, Bild 1 von 3 Lenovo 300e Chromebook Speakers Replacement, Speakers: Schritt 5, Bild 2 von 3 Lenovo 300e Chromebook Speakers Replacement, Speakers: Schritt 5, Bild 3 von 3
    • Remove a single 5 mm screw from each speaker using a Phillips #2 screwdriver.
  6. Lenovo 300e Chromebook Speakers Replacement: Schritt 6, Bild 1 von 3 Lenovo 300e Chromebook Speakers Replacement: Schritt 6, Bild 2 von 3 Lenovo 300e Chromebook Speakers Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the speaker cable from the motherboard.
    • Remove the speakers from the laptop.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 188
