Zum Hauptinhalt wechseln
Lenovo 300e Chromebook USB and Charging Ports Replacement
Was du brauchst
  1. Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: Schritt 1, Bild 1 von 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: Schritt 1, Bild 2 von 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook USB and Charging Ports Replacement: Schritt 2, Bild 1 von 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: Schritt 2, Bild 2 von 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: Schritt 2, Bild 3 von 3
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: Schritt 3, Bild 1 von 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: Schritt 3, Bild 2 von 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: Schritt 3, Bild 3 von 3
    • Remove three 5 mm screws from the USB board using a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook USB and Charging Ports Replacement: Schritt 4, Bild 1 von 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: Schritt 4, Bild 2 von 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: Schritt 4, Bild 3 von 3
    • Detach the white and blue ribbon cable from its cable connector on the USB board.
    • Remove the USB board from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Do you have same instructions for Lenovo 300e Gen2, I opened and usb ports are soldered with the motherboard, I am having some troubles to replace the usb c, any recommendation?
Juan Raul Hernandez - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 37
Insgesamt: 1,446
