Einleitung
This guide will show you how to replace the speakers in the Lenovo 500e 2nd Gen Chromebook, model number: 81MC005AUS. The speaker allows the user to hear the sounds played from the device. If the sound is not working or the sound quality is poor, check out our troubleshooting page.
Was du brauchst
Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
Go along the edge of the back panel with an iFixit opening tool until it pops loose.
Remove the back panel from the laptop.
Remove the two 4 mm screws (one on each speaker) using a Phillips #00 screwdriver.
Use the iFixit opening tool to detach the right speaker cable from the motherboard.
