Zum Hauptinhalt wechseln
Lenovo A8-50 Motherboard and Speaker Replacement
Was du brauchst
  1. Lenovo A8-50 Motherboard and Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the back cover by prying it open with the metal spudger tool.
  2. Lenovo A8-50 Motherboard and Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the two screws with a PH000 head screwdriver.
    • Keep all your screws in one place.
  3. Lenovo A8-50 Motherboard and Speaker Replacement: Schritt 3, Bild 1 von 1
    • Remove the metal piece.
    • Keep this piece safe, as you will need it to reassemble the device again.
  4. Lenovo A8-50 Motherboard and Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery by lifting it up using a plastic spudger.
  5. Lenovo A8-50 Motherboard and Speaker Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the cable from the connection.
    • Be careful not to tear or bend the cable.
  6. Lenovo A8-50 Motherboard and Speaker Replacement, Motherboard and Speaker: Schritt 6, Bild 1 von 1
    • Unscrew the 5 black screws, and the 9 silver screws with a PH000 head screwdriver.
    • Set aside carefully.
  7. Lenovo A8-50 Motherboard and Speaker Replacement: Schritt 7, Bild 1 von 2 Lenovo A8-50 Motherboard and Speaker Replacement: Schritt 7, Bild 2 von 2
    • Remove the two black panels and the clear circle piece.
  8. Lenovo A8-50 Motherboard and Speaker Replacement: Schritt 8, Bild 1 von 1
    • Lift up the motherboard carefully, ensuring that you lift the speaker housing and the motherboard together
  9. Lenovo A8-50 Motherboard and Speaker Replacement: Schritt 9, Bild 1 von 1
    • Lift the bottom speaker piece up carefully
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jay Shah
503 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 1,283
