Einleitung
This guide will give you a step-by-step process for replacing any keyboard key on the Lenovo Edge 15. The key on the keyboard may need to be replaced if any food or liquid is caught under the key.
Was du brauchst
Using the plastic opening tool, pry off the key.
Pry off the plastic keyboard connector.
Locate the metal hooks where the plastic keys are held in.
Insert the keys into the metal hook.
Evenly push the plastic keys into the metal hooks.
Evenly insert the key onto the plastic keys.
Fin.
Fin.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Images are blurry, which makes this guide much harder to follow. Other images have too much light, making it impossible to see the grooves on the pieces. Additionally, the image of the smaller piece being inserted into the larger piece is incorrect. The smaller piece should be rotated 180 degrees. It should tuck in with the larger piece, creating a larger piece that is essentially flat. The instructions of “The smooth part of both plastic keys always faces away from the keyboard.“ is also misleading. The larger piece has some large grooves that the smaller piece gets tucked into. These grooves (which are obscured after the smaller piece is inserted) should face away from the keyboard. So really, the rough part of the larger piece faces away from the keyboard, not the smooth part. Put another way, the smaller piece can rotate inside the larger piece. The rods on the smaller piece (which the key attaches to) should rotate away from the keyboard. I’m not proud that I spent over an hour figuring this out.
