Einleitung
This guide will show how to remove and install ram card in your Edge 15. This can be used to replace a broken card or to add more ram to increase the ram in your computer.
Was du brauchst
With the laptop upside-down, remove all 11 M2 x 6.0mm screws from the cover plate using the Phillips #0 screwdriver.
Gently lift the cover plate off the body of the laptop, ensuring that it does not pull on any components such as the USB ports.
3 weitere Personen haben diese Anleitung absolviert.
