Zum Hauptinhalt wechseln
Lenovo Edge 2-1580 Fan Replacement
Was du brauchst
  1. Lenovo Edge 2-1580 Fan Replacement, Battery: Schritt 1, Bild 1 von 2 Lenovo Edge 2-1580 Fan Replacement, Battery: Schritt 1, Bild 2 von 2
    • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  2. Lenovo Edge 2-1580 Fan Replacement: Schritt 2, Bild 1 von 2 Lenovo Edge 2-1580 Fan Replacement: Schritt 2, Bild 2 von 2
    • Using a plastic opening tool, pull out the back panel from the laptop.
  3. Lenovo Edge 2-1580 Fan Replacement: Schritt 3, Bild 1 von 3 Lenovo Edge 2-1580 Fan Replacement: Schritt 3, Bild 2 von 3 Lenovo Edge 2-1580 Fan Replacement: Schritt 3, Bild 3 von 3
    • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
    • Disconnect the battery connector from the motherboard.
  4. Lenovo Edge 2-1580 Fan Replacement: Schritt 4, Bild 1 von 1
    • Pull the battery outward and remove it from the rest of the laptop.
  5. Lenovo Edge 2-1580 Fan Replacement, Fan: Schritt 5, Bild 1 von 3 Lenovo Edge 2-1580 Fan Replacement, Fan: Schritt 5, Bild 2 von 3 Lenovo Edge 2-1580 Fan Replacement, Fan: Schritt 5, Bild 3 von 3
    • Remove the 5.4 mm Phillips #0 screw holding the Wireless Network Card.
    • The network card will pop up by itself.
  6. Lenovo Edge 2-1580 Fan Replacement: Schritt 6, Bild 1 von 2 Lenovo Edge 2-1580 Fan Replacement: Schritt 6, Bild 2 von 2
    • Grab the network card and gently pull it out.
  7. Lenovo Edge 2-1580 Fan Replacement: Schritt 7, Bild 1 von 2 Lenovo Edge 2-1580 Fan Replacement: Schritt 7, Bild 2 von 2
    • Pull out the RAM metallic cover.
  8. Lenovo Edge 2-1580 Fan Replacement: Schritt 8, Bild 1 von 2 Lenovo Edge 2-1580 Fan Replacement: Schritt 8, Bild 2 von 2
    • Grab the black insulating tape and pull it out.
  9. Lenovo Edge 2-1580 Fan Replacement: Schritt 9, Bild 1 von 2 Lenovo Edge 2-1580 Fan Replacement: Schritt 9, Bild 2 von 2
    • Using the Phillips #0 screwdriver, remove the (6) six fan screws from the device.
    • (5) Five copper and (1) one silver Phillips #0 5.4mm screws.
    • Disconnect the fan from the motherboard.
  10. Lenovo Edge 2-1580 Fan Replacement: Schritt 10, Bild 1 von 2 Lenovo Edge 2-1580 Fan Replacement: Schritt 10, Bild 2 von 2
    • Unplug the Fan connector from its socket on the motherboard.
  11. Lenovo Edge 2-1580 Fan Replacement: Schritt 11, Bild 1 von 2 Lenovo Edge 2-1580 Fan Replacement: Schritt 11, Bild 2 von 2
    • Carefully remove the fan from the laptop.
Abschluss
USF Tampa, Team S14-G1, Boczar Fall 2017 Mitglied von USF Tampa, Team S14-G1, Boczar Fall 2017
USFT-BOCZAR-F17S14G1
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Looks like heat sink and fan are one unit. Advice for regular dust cleaning? How was the condition of the factory thermal paste?
cfryhover - Antwort
Where can one find this fan?
Gabriel Rivera - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 645
