Einleitung
The guide will show you how to remove the storage hard drive unit that comes with the laptop. It is compatible with any 2.5" storage solutions like a SSD or HDD.
Was du brauchst
Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
Disconnect the battery connector from the motherboard.
Using the Phillips #0 screwdriver, remove the (3) three 3 mm screws.
Slide the drive away from the connector by applying pressure on the two side tabs where screws were removed. Use a plastic opening tool as a lever to lift the drive out.
5 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
The Edge 2 requires a hard drive of 7mm or less or the bottom cover will not fit properly.
Thank you, was looking everywhere to find that out!!!
Thank you, your help was so useful.
