Zum Hauptinhalt wechseln
Lenovo Essential B570 DVD Drive Replacement
Was du brauchst
  1. Lenovo Essential B570 DVD Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn over laptop.
    • Switch open the left battery lock.
    • If you are replacing inner components of the laptop, it is recommended to remove the battery first to avoid damage to the laptop.
  2. Lenovo Essential B570 DVD Drive Replacement: Schritt 2, Bild 1 von 1
    • Hold the right battery lock open with one hand while removing the battery itself with the other.
  3. Lenovo Essential B570 DVD Drive Replacement, Back Panel: Schritt 3, Bild 1 von 1
    • Loosen the five Philips screws that secure the panel.
    • The screws do not actually fully remove from the panel. Loosening them as much as you can will be enough to disconnect them from the laptop.
  4. Lenovo Essential B570 DVD Drive Replacement: Schritt 4, Bild 1 von 3 Lenovo Essential B570 DVD Drive Replacement: Schritt 4, Bild 2 von 3 Lenovo Essential B570 DVD Drive Replacement: Schritt 4, Bild 3 von 3
    • Prop open the cover with a plastic opening tool.
    • If the cover does not come off easily, do not force it. Make sure all screws are loosened.
  5. Lenovo Essential B570 DVD Drive Replacement, DVD Drive: Schritt 5, Bild 1 von 1
    • Unscrew the one 4 mm Phillips screw that is securing your DVD drive to the frame.
  6. Lenovo Essential B570 DVD Drive Replacement: Schritt 6, Bild 1 von 2 Lenovo Essential B570 DVD Drive Replacement: Schritt 6, Bild 2 von 2
    • Grab your DVD drive and pull outwards.
Abschluss
UMass Dartmouth, Team 4-5, Catania Fall 2015 Mitglied von UMass Dartmouth, Team 4-5, Catania Fall 2015
UMASSD-CATANIA-F15S4G5
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 1,213
