Zum Hauptinhalt wechseln
Lenovo Essential B570 RAM Replacement
Was du brauchst
  1. Lenovo Essential B570 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn over laptop.
    • Switch open the left battery lock.
    • If you are replacing inner components of the laptop, it is recommended to remove the battery first to avoid damage to the laptop.
  2. Lenovo Essential B570 RAM Replacement: Schritt 2, Bild 1 von 1
    • Hold the right battery lock open with one hand while removing the battery itself with the other.
  3. Lenovo Essential B570 RAM Replacement, Back Panel: Schritt 3, Bild 1 von 1
    • Loosen the five Philips screws that secure the panel.
    • The screws do not actually fully remove from the panel. Loosening them as much as you can will be enough to disconnect them from the laptop.
  4. Lenovo Essential B570 RAM Replacement: Schritt 4, Bild 1 von 3 Lenovo Essential B570 RAM Replacement: Schritt 4, Bild 2 von 3 Lenovo Essential B570 RAM Replacement: Schritt 4, Bild 3 von 3
    • Prop open the cover with a plastic opening tool.
    • If the cover does not come off easily, do not force it. Make sure all screws are loosened.
  5. Lenovo Essential B570 RAM Replacement, RAM: Schritt 5, Bild 1 von 2 Lenovo Essential B570 RAM Replacement, RAM: Schritt 5, Bild 2 von 2
    • Release your RAM by pulling its locks away from one another.
  6. Lenovo Essential B570 RAM Replacement: Schritt 6, Bild 1 von 2 Lenovo Essential B570 RAM Replacement: Schritt 6, Bild 2 von 2
    • Remove RAM by carefully pulling it away from its socket.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team 4-5, Catania Fall 2015 Mitglied von UMass Dartmouth, Team 4-5, Catania Fall 2015
UMASSD-CATANIA-F15S4G5
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 20
Insgesamt: 895
