Zum Hauptinhalt wechseln
Lenovo Essential G555-0873 CPU Replacement
Was du brauchst
  1. Lenovo Essential G555-0873 CPU Replacement, Bottom Panel: Schritt 1, Bild 1 von 1
    • Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Note that the screws will not come all the way out of the sockets.
  2. Lenovo Essential G555-0873 CPU Replacement: Schritt 2, Bild 1 von 1
    • Lift from the notch until the back panel comes up.
  3. Lenovo Essential G555-0873 CPU Replacement, Fan: Schritt 3, Bild 1 von 1
    • Disconnect the fan from the motherboard by pulling the plug shown in the picture.
  4. Lenovo Essential G555-0873 CPU Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the three 4.6mm screws shown in the picture.
  5. Lenovo Essential G555-0873 CPU Replacement: Schritt 5, Bild 1 von 1
    • Gently lift the fan straight up until it is lifted out of the case.
  6. Lenovo Essential G555-0873 CPU Replacement, Heat Sink: Schritt 6, Bild 1 von 1
    • Unscrew the four 7.3 mm screws shown in the picture.
    • Note that springs are attached to the screws. Do not remove the springs.
  7. Lenovo Essential G555-0873 CPU Replacement: Schritt 7, Bild 1 von 2 Lenovo Essential G555-0873 CPU Replacement: Schritt 7, Bild 2 von 2
    • Pull the heat sink assembly out of the laptop.
  8. Lenovo Essential G555-0873 CPU Replacement, CPU: Schritt 8, Bild 1 von 2 Lenovo Essential G555-0873 CPU Replacement, CPU: Schritt 8, Bild 2 von 2
    • Use a flat-head screwdriver on the hinge shown, and turn counter-clockwise to the unlock position
  9. Lenovo Essential G555-0873 CPU Replacement: Schritt 9, Bild 1 von 1
    • Remove the CPU
    • There will be old thermal paste on the CPU and heat sink which should be wiped off using microfiber cloth.
    • Before putting the heat sink back in, a small droplet of thermal paste should be applied onto the center of the CPU.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 381
