Zum Hauptinhalt wechseln
Einleitung
You can use this guide to remove the heat sink in for cleaning, replacement or to gain access to the CPU.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Note that the screws will not come all the way out of the sockets.
  2. Lift from the notch until the back panel comes up.
    • Lift from the notch until the back panel comes up.
  3. Disconnect the fan from the motherboard by pulling the plug shown in the picture.
    • Disconnect the fan from the motherboard by pulling the plug shown in the picture.
  4. Unscrew the three 4.6mm screws shown in the picture.
    • Unscrew the three 4.6mm screws shown in the picture.
  5. Gently lift the fan straight up until it is lifted out of the case.
    • Gently lift the fan straight up until it is lifted out of the case.
  6. Unscrew the four 7.3 mm screws shown in the picture.
    • Unscrew the four 7.3 mm screws shown in the picture.
    • Note that springs are attached to the screws. Do not remove the springs.
  7. Pull the heat sink assembly out of the laptop. Pull the heat sink assembly out of the laptop.
    • Pull the heat sink assembly out of the laptop.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 100
