Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The Lenovo G570 has a 6-cell Lithium-ion battery that fits into the bottom side of the computer. Battery removal is an essential first step to any further repair or disassembly of the device.
  1. Turn off the laptop.
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to unplug the cable could result in electric shock.
    • Turn the computer upside down.
  2. Locate the two switches that lock the battery. Push the right switch outwards to unlock the battery.
    • Locate the two switches that lock the battery.
    • Push the right switch outwards to unlock the battery.
  3. Push and hold the left switch outwards to unlock the battery. Pull the battery away from the computer.
    • Push and hold the left switch outwards to unlock the battery.
    • Pull the battery away from the computer.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Nina Francisco
358 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G1, Simcock Spring 2018 Mitglied von UMass Dartmouth, Team S1-G1, Simcock Spring 2018
UMASSD-SIMCOCK-S18S1G1
3 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 6
Insgesamt: 588
