Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
CD Drives have various reasons for not working any longer. Luckily, this guide will show how easy it is to install a new one.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn off the laptop.
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to unplug the cable could result in electric shock.
    • Turn the computer upside down.
  2. Locate the two switches that lock the battery. Push the right switch outwards to unlock the battery.
    • Locate the two switches that lock the battery.
    • Push the right switch outwards to unlock the battery.
  3. Push and hold the left switch outwards to unlock the battery. Pull the battery away from the computer.
    • Push and hold the left switch outwards to unlock the battery.
    • Pull the battery away from the computer.
  4. Remove the 9mm Phillips #0 screw holding the CD drive in place.
    • Remove the 9mm Phillips #0 screw holding the CD drive in place.
  5. Slide out the entire CD drive from the body of the laptop.
    • Slide out the entire CD drive from the body of the laptop.
Abschluss
Lucio
181 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G1, Simcock Spring 2018 Mitglied von UMass Dartmouth, Team S1-G1, Simcock Spring 2018
UMASSD-SIMCOCK-S18S1G1
3 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 11
Insgesamt: 172
