Einleitung
Often times if a computer is overheating, the fan may not be working properly. This guide will show a user how to replace a fan that is no longer working.
Was du brauchst
Turn off the laptop.
Disconnect the charging cable.
Turn the computer upside down.
Locate the two switches that lock the battery.
Push the right switch outwards to unlock the battery.
Push and hold the left switch outwards to unlock the battery.
Pull the battery away from the computer.
With the screws removed, insert the plastic opening tool into the groove located on the right side.
Begin to pry up, and the plate should lift up from the body of the laptop.
While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
