Zum Hauptinhalt wechseln
Lenovo Essential G570 RAM Replacement
Was du brauchst
  1. Lenovo Essential G570 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to unplug the cable could result in electric shock.
    • Turn the computer upside down.
  2. Lenovo Essential G570 RAM Replacement: Schritt 2, Bild 1 von 2 Lenovo Essential G570 RAM Replacement: Schritt 2, Bild 2 von 2
    • Locate the two switches that lock the battery.
    • Push the right switch outwards to unlock the battery.
  3. Lenovo Essential G570 RAM Replacement: Schritt 3, Bild 1 von 2 Lenovo Essential G570 RAM Replacement: Schritt 3, Bild 2 von 2
    • Push and hold the left switch outwards to unlock the battery.
    • Pull the battery away from the computer.
  4. Lenovo Essential G570 RAM Replacement, Back Panel: Schritt 4, Bild 1 von 1
    • Turn the laptop over so that the bottom side is facing up.
  5. Lenovo Essential G570 RAM Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
    • The screws do not come out fully from the back plate. They stay attached to the plate itself.
  6. Lenovo Essential G570 RAM Replacement: Schritt 6, Bild 1 von 3 Lenovo Essential G570 RAM Replacement: Schritt 6, Bild 2 von 3 Lenovo Essential G570 RAM Replacement: Schritt 6, Bild 3 von 3
    • With the screws removed, insert the plastic opening tool into the groove located on the right side.
    • Begin to pry up, and the plate should lift up from the body of the laptop.
    • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
  7. Lenovo Essential G570 RAM Replacement, RAM: Schritt 7, Bild 1 von 1
    • Using your fingers, hold open the two clips holding the top RAM in place.
    • The two RAM chips are placed one on top of another. It is important to take the top one out first to easily access the bottom one.
    • With the clips held away from the RAM, slide the top stick out from it's connection.
  8. Lenovo Essential G570 RAM Replacement: Schritt 8, Bild 1 von 1
    • With the top RAM stick removed, repeat the same process for the bottom piece. Begin by holding the two clips away from the RAM.
    • With the clips held out, slide the RAM out from the connection.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team S1-G1, Simcock Spring 2018 Mitglied von UMass Dartmouth, Team S1-G1, Simcock Spring 2018
UMASSD-SIMCOCK-S18S1G1
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 641
