Einleitung
This guide is intended to help you to replace your battery. The battery may need to be replaced in instances where your computer will not hold a charge or turn on.
Was du brauchst
Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
Wedge the plastic opening tool into the small space under the back panel.
Use the plastic opening tool as a lever to separate the bottom panel from the computer.
Slide the tool along the edges of the computer until the bottom panel is completely separated.
Locate the six 3.5mm Phillips head screws along the edges of the battery.
Remove all six of the screws using a size 0 Phillips screwdriver.
Locate the multicolored power cables coming directly from the top of the battery and into the motherboard.
Use a spudger to slide the power cables down and away from its port on the motherboard.
4 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
I lifted the battery out from the computer twice. Now what? I used the spudger and I can't bloody well remove screws that are already removed, can I? Reverse order my eye! Then I caught my dick in the fan. These instructions are impossibly difficult! Thanks a lot!!
Where do you purchase a replacement battery? And just what is a spudger anyway? It is not on your list of things to purchase so where do I get one?
You don’t really need a spudger. A guitar pick or even a flathead screwdriver (if you’re careful) can work, although in my personal experience just being careful while prying it out is perfectly fine. It’s used so you don’t rip off the little plastic clips that hold the bottom chassis together.
