Zum Hauptinhalt wechseln
Lenovo Flex 3-1120 Hard Drive Replacement
Was du brauchst
  1. Lenovo Flex 3-1120 Hard Drive Replacement, Bottom Panel: Schritt 1, Bild 1 von 1
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Lenovo Flex 3-1120 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 1
    • Locate the hard drive in the bottom left of your computer.
  6. Lenovo Flex 3-1120 Hard Drive Replacement: Schritt 6, Bild 1 von 2 Lenovo Flex 3-1120 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Locate the three 3.5mm Phillips screws on the corners of the hard drive.
    • Remove the three screws with a size 0 Phillips screwdriver.
  7. Lenovo Flex 3-1120 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Follow the wire out from the right side of the hard drive to locate where the hard drive connects to the motherboard.
  8. Lenovo Flex 3-1120 Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Lift off the strip of tape securing the wire down to the computer.
  9. Lenovo Flex 3-1120 Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Pull the connector out of its port on the motherboard.
  10. Lenovo Flex 3-1120 Hard Drive Replacement: Schritt 10, Bild 1 von 1
    • Lift the hard drive out from the computer.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Geoff Bentz
934 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 7-1, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 7-1, Catania Spring 2016
UMASSD-CATANIA-S16S7G1
4 Mitglieder
7 Anleitungen geschrieben
4 Kommentare
How do you reload operating system.... for example windows 10?
supermac200 - Antwort
How do I get Windows 10 working again after replacing hard drive on Lenovo Flex 3?
arcinko - Antwort
Demo models of this do not have any SATA connector.
Elilla Shadowheart - Antwort
That sata connector is the worst thing ever
dilleremail - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 46
Insgesamt: 10,768
