Zum Hauptinhalt wechseln
Lenovo Flex 3-1120 Network Card Replacement
Was du brauchst
  1. Lenovo Flex 3-1120 Network Card Replacement, Bottom Panel: Schritt 1, Bild 1 von 1
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Network Card Replacement: Schritt 2, Bild 1 von 2 Lenovo Flex 3-1120 Network Card Replacement: Schritt 2, Bild 2 von 2
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Network Card Replacement: Schritt 3, Bild 1 von 1
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Network Card Replacement: Schritt 4, Bild 1 von 1
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Network Card Replacement, Network Card: Schritt 5, Bild 1 von 1
    • Locate the network card on the top right of the computer.
  6. Lenovo Flex 3-1120 Network Card Replacement: Schritt 6, Bild 1 von 2 Lenovo Flex 3-1120 Network Card Replacement: Schritt 6, Bild 2 von 2
    • Locate the single 3.5mm Phillips head screw on the right edge of the network card.
    • Remove the single screw with a size 0 Phillips screwdriver.
  7. Lenovo Flex 3-1120 Network Card Replacement: Schritt 7, Bild 1 von 1
    • Slide the network card out to the right to remove it from the motherboard.
  8. Lenovo Flex 3-1120 Network Card Replacement: Schritt 8, Bild 1 von 2 Lenovo Flex 3-1120 Network Card Replacement: Schritt 8, Bild 2 von 2
    • Locate the black and white antenna wires that are connected to the right edge of the network card.
    • Wiggle and pull upward on the two antenna cords connecting to the card to remove them.
Abschluss
Geoff Bentz
934 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 7-1, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 7-1, Catania Spring 2016
UMASSD-CATANIA-S16S7G1
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Where can I buy a replacement card? Can I replace the AC-3160 with the newer 7265D card?
barence321 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 818
