Zum Hauptinhalt wechseln
Lenovo Flex 3-1120 Speakers Replacement
Was du brauchst
  1. Lenovo Flex 3-1120 Speakers Replacement, Bottom Panel: Schritt 1, Bild 1 von 1
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Speakers Replacement: Schritt 2, Bild 1 von 2 Lenovo Flex 3-1120 Speakers Replacement: Schritt 2, Bild 2 von 2
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Speakers Replacement: Schritt 3, Bild 1 von 1
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Speakers Replacement: Schritt 4, Bild 1 von 1
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Speakers Replacement, Speakers: Schritt 5, Bild 1 von 1
    • Locate the speakers at the bottom left and right corners of the computer.
  6. Lenovo Flex 3-1120 Speakers Replacement: Schritt 6, Bild 1 von 2 Lenovo Flex 3-1120 Speakers Replacement: Schritt 6, Bild 2 von 2
    • Locate the two 1mm Phillips head screws on both speakers.
    • Remove both screws from each speaker.
  7. Lenovo Flex 3-1120 Speakers Replacement: Schritt 7, Bild 1 von 2 Lenovo Flex 3-1120 Speakers Replacement: Schritt 7, Bild 2 von 2
    • Locate where the two speaker wires join at the center of the computer.
    • Follow the wires directly upward to where they connect into the motherboard.
  8. Lenovo Flex 3-1120 Speakers Replacement: Schritt 8, Bild 1 von 1
    • Using the spudger, pull the wire down and away from the motherboard to disconnect it.
Abschluss
Geoff Bentz
934 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 7-1, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 7-1, Catania Spring 2016
UMASSD-CATANIA-S16S7G1
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 395
