Zum Hauptinhalt wechseln
Lenovo Flex 6-11IGM Heat Sink Replacement
Was du brauchst
  1. Lenovo Flex 6-11IGM Heat Sink Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Heat Sink Replacement: Schritt 2, Bild 1 von 2 Lenovo Flex 6-11IGM Heat Sink Replacement: Schritt 2, Bild 2 von 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Heat Sink Replacement: Schritt 3, Bild 1 von 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Heat Sink Replacement: Schritt 4, Bild 1 von 2 Lenovo Flex 6-11IGM Heat Sink Replacement: Schritt 4, Bild 2 von 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Heat Sink Replacement, Battery: Schritt 5, Bild 1 von 2 Lenovo Flex 6-11IGM Heat Sink Replacement, Battery: Schritt 5, Bild 2 von 2
    • Remove the five 3.9 mm Phillips #00 black screws holding the battery in place.
  6. Lenovo Flex 6-11IGM Heat Sink Replacement: Schritt 6, Bild 1 von 3 Lenovo Flex 6-11IGM Heat Sink Replacement: Schritt 6, Bild 2 von 3 Lenovo Flex 6-11IGM Heat Sink Replacement: Schritt 6, Bild 3 von 3
    • Pull out the multicolored connecting cables using an iFixit opening tool.
  7. Lenovo Flex 6-11IGM Heat Sink Replacement: Schritt 7, Bild 1 von 1
    • Remove the now disconnected battery from the laptop.
  8. Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: Schritt 8, Bild 1 von 3 Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: Schritt 8, Bild 2 von 3 Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: Schritt 8, Bild 3 von 3
    • Disconnect the ribbon connector from both ends by disengaging the black latch and pulling it directly from its port.
  9. Lenovo Flex 6-11IGM Heat Sink Replacement: Schritt 9, Bild 1 von 2 Lenovo Flex 6-11IGM Heat Sink Replacement: Schritt 9, Bild 2 von 2
    • Remove the 3.5 mm length screws in the numbered order from 1-10 using the Phillips #00 screwdriver (not all are shown in the first image).
    • Remove the heat sink.
Abschluss
Rie Kuraoka
886 Reputation
7 Anleitungen geschrieben
Cal Poly, Team S7-G10, Paton Spring 2020 Mitglied von Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 292
