Zum Hauptinhalt wechseln
Lenovo Flex 6-11IGM Trackpad Replacement
Was du brauchst
  1. Lenovo Flex 6-11IGM Trackpad Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 2, Bild 1 von 2 Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 2, Bild 2 von 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 3, Bild 1 von 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 4, Bild 1 von 2 Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 4, Bild 2 von 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Trackpad Replacement, Battery: Schritt 5, Bild 1 von 2 Lenovo Flex 6-11IGM Trackpad Replacement, Battery: Schritt 5, Bild 2 von 2
    • Remove the five 3.9 mm Phillips #00 black screws holding the battery in place.
  6. Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 6, Bild 1 von 3 Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 6, Bild 2 von 3 Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 6, Bild 3 von 3
    • Pull out the multicolored connecting cables using an iFixit opening tool.
  7. Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 7, Bild 1 von 1
    • Remove the now disconnected battery from the laptop.
  8. Lenovo Flex 6-11IGM Trackpad Replacement, Trackpad: Schritt 8, Bild 1 von 2 Lenovo Flex 6-11IGM Trackpad Replacement, Trackpad: Schritt 8, Bild 2 von 2
    • Remove the connecting wire labelled "TP" by lifting the tab with the opening tool.
  9. Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 9, Bild 1 von 3 Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 9, Bild 2 von 3 Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 9, Bild 3 von 3
    • Disconnect the keyboard ribbon from the motherboard by lifting the black tab and pulling the ribbon out with the opening tool.
  10. Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 10, Bild 1 von 1
    • Pull up the black safety tape.
  11. Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 11, Bild 1 von 2 Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 11, Bild 2 von 2
    • Remove the three silver 2.3 mm Phillips #00 screws.
    • The third one is under the black tape.
  12. Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 12, Bild 1 von 2 Lenovo Flex 6-11IGM Trackpad Replacement: Schritt 12, Bild 2 von 2
    • Slide the trackpad up from its seat using the opening tool and remove it.
Abschluss
Rie Kuraoka
886 Reputation
7 Anleitungen geschrieben
Cal Poly, Team S7-G10, Paton Spring 2020 Mitglied von Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 302
