Einleitung
This replacement is extremely easy and doesn't require any tools. Please make sure the computer is off and unplugged before starting the guide.
  1. At the top of the laptop you will see two switches, like in image one and two. Pull the switches outwards with your thumb, towards the unlocked lock. Pull the switches outwards with your thumb, towards the unlocked lock.
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Once both switches are pulled, the battery should pop out. Once both switches are pulled, the battery should pop out. Once both switches are pulled, the battery should pop out.
    • Once both switches are pulled, the battery should pop out.
  4. Now you are ready to insert your new battery.
    • Now you are ready to insert your new battery.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Kalah
97 Reputation
1 Anleitung geschrieben
Sam Houston State, Team S16-G4, Nardone Spring 2018 Mitglied von Sam Houston State, Team S16-G4, Nardone Spring 2018
SHSU-NARDONE-S18S16G4
5 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 28
Insgesamt: 250
