Zum Hauptinhalt wechseln
Lenovo G40-30 Keyboard Replacement
Was du brauchst
  1. Lenovo G40-30 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 Lenovo G40-30 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 Lenovo G40-30 Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Lenovo G40-30 Keyboard Replacement: Schritt 2, Bild 1 von 3 Lenovo G40-30 Keyboard Replacement: Schritt 2, Bild 2 von 3 Lenovo G40-30 Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Once both switches are pulled, the battery should pop out.
  3. Lenovo G40-30 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Now you are ready to insert your new battery.
  4. Lenovo G40-30 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 2 Lenovo G40-30 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 2
    • Use a JIS #1 screwdriver to remove the two 7 mm screws.
  5. Lenovo G40-30 Keyboard Replacement: Schritt 5, Bild 1 von 2 Lenovo G40-30 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the back panel by sliding it away from the battery.
  6. Lenovo G40-30 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Use a JIS #1 screwdriver to remove the three 7 mm screws.
  7. Lenovo G40-30 Keyboard Replacement: Schritt 7, Bild 1 von 2 Lenovo G40-30 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Wedge the plastic opening tool in-between the keyboard and the base of the laptop.
    • Continue using the plastic opening tool to pry around the edge until the keyboard is completely freed form the frame.
    • The keyboard should only be connected by a ribbon on the underside of the keyboard.
    • It is recommended that you slowly pull the keyboard out as your move around the edge. As in picture 2.
    • Be careful not to pull the keyboard too far away from the face as it will damage the data ribbon.
  8. Lenovo G40-30 Keyboard Replacement: Schritt 8, Bild 1 von 3 Lenovo G40-30 Keyboard Replacement: Schritt 8, Bild 2 von 3 Lenovo G40-30 Keyboard Replacement: Schritt 8, Bild 3 von 3
    • Use the tweezers to lift the black hinge on the ribbon connector.
    • Then pull the ribbon from the connector and remove the keyboard from the laptop.
  9. Lenovo G40-30 Keyboard Replacement: Schritt 9, Bild 1 von 1
    • Now your keyboard is free to be replaced!
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Luke
314 Reputation
1 Anleitung geschrieben
Sam Houston State, Team S16-G4, Nardone Spring 2018 Mitglied von Sam Houston State, Team S16-G4, Nardone Spring 2018
SHSU-NARDONE-S18S16G4
5 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
thanks ….terimakasih sangat membantu…..
herman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 2,076
